Knock sensor question
Old Jul 20, 2015 | 04:20 PM
mlm0's Avatar
mlm0
Default Knock sensor question
1989 L98
Does the knock sensor or its circuit have any effect on engine at idle?
Old Jul 20, 2015 | 05:04 PM
Aardwolf's Avatar
Aardwolf
Yes
Old Jul 20, 2015 | 05:31 PM
mlm0's Avatar
mlm0
Originally Posted by Aardwolf
Yes
Can it cause idle to go up and down very slightly
Old Jul 20, 2015 | 06:49 PM
antfarmer2's Avatar
antfarmer2
There are regular maintance and yes
Old Jul 20, 2015 | 07:48 PM
tequilaboy's Avatar
tequilaboy
In the 89 $6E bins that I've checked, knock (retard) is disabled below 2 mph or below 650 rpm auto/850 rpm manual.
So a stationary vehicle at idle should not be affected by the knock sensor.
Old Jul 20, 2015 | 07:52 PM
DanielRicany's Avatar
DanielRicany
Idle is probably gonna move around a very small amount on a properly functioning car. You get into 200 RPMs or greater than you are looking at vacuum leaks, maybe leaking secondary ignition system, etc.
Old Jul 20, 2015 | 10:57 PM
mlm0's Avatar
mlm0
It's less then 200 rpms just re-read FSM and it states below 900 rpms, knock sensor doesn't effect it.
Old Jul 20, 2015 | 11:06 PM
mlm0's Avatar
mlm0
I'm trying to figure a way to raise my idle about 75 to 100 rpms at idle in gear without burning chip which I don't have equipment or knowledge to do myself. I have done everything I know and what others have told me to try to get rid of miss at idle. When I first stop at light, idle seems fine then drops lower causing rough idle. NO vacuum leaks. I'm starting to think broken valve spring
Old Jul 21, 2015 | 12:43 AM
Cliff Harris's Avatar
Cliff Harris
The idle speed is controlled by the ECM, so the only way to change it is to program a chip.
I suggest a minimum idle adjustment:
http://forums.corvetteforum.com/1570563689-post1.html
A miss is usually an ignition problem. Check your wires in a dark garage for arcing.
Old Jul 21, 2015 | 06:26 AM
WW7's Avatar
WW7
You may want to try cleaning your IAC and the air channels it uses.....This could cause a fluctuating idle..This should be done every few years anyway as preventive maintainance......WW
Old Jul 21, 2015 | 09:25 AM
volkswagens-for-life's Avatar
How do you tell if a knock sensor is working properly, aside from getting a new one or running software on a laptop?
Old Jul 21, 2015 | 10:05 AM
mlm0's Avatar
mlm0
I have done all things mentioned several times
Old Jul 21, 2015 | 10:24 AM
WW7's Avatar
WW7
Hook up a timing light ,see where your timing is set, take a wrench or hammer and bang on you headers or exhaust manifold and you will see your timing retard......This is how I check mine, but instead of a timing light I use a scanner to watch the timing retard...WW
Old Jul 21, 2015 | 10:25 AM
Ohhh I see. Thank you.
To Knock sensor question
