intermitten electrical
Have been having various electrical glitches, with things like
antenna once in a while wont operate, cabin lights wont go out,
a/c turns on but not off. I believe that I have a ground problem.
The question is where are these ground and what is the best way
to clean them, repair them or replace them??
As always thanks
Pr. Putz
G101 - On top of the frame rail under the power brake booster.
G104 - Just above the oil filter on the side of the block.
This is the main engine ground.
Many problems have been solved by cleaning and tightening this connection.
G115 - Just above the horn on the driver's side.
G116 - Just above the horn on the passenger side.
G117 - On the front crossmember next to the power steering reservoir.
G125 - In the passenger side footwell on the door hinge pillar.
G??? - I believe there is also a ground in the driver's side footwell on the door hinge pillar but it is not shown in the shop manual.
G201 - On the frame rail under the air conditioner evaporator housing.
It does not have an arrow in this picture. It's next to splice S128.
G320 - On the driver's door striker pillar next to the rear compartment lamp.
G401 - On the passenger's door striker pillar next to the rear compartment lamp.
