time to replace the plugs?
Old Aug 19, 2002 | 11:25 PM
Utahvette's Avatar
Utahvette
Default time to replace the plugs?
92 and later vettes need plug replacement at 100,000 miles according to the manual. My question is do the plugs really last that long? can they fail prematurely?
Old Aug 20, 2002 | 02:52 AM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: time to replace the plugs? (Utahvette)
I pulled mine at 100K and they were in really good shape. Still had the pucks on and all edges still looked sharp enough for use.
I bought the car used and the previous owner didn't run it very hard. Lotsa highway miles so I'm sure that contributed to the long life.
When you change the plugs, go ahead and do the wires too. You're already in there :)
Old Aug 20, 2002 | 09:57 AM
PTz-92-LT1's Avatar
PTz-92-LT1
92 and later vettes really last that long. But it is contingent upon how the motor has been run and the quality of all the components.
Ditto on changing the wires while you are at it. Also make sure and use antiseize on the threads and di-electric silicon on the wire boots. By all means be careful when removing the old ones, you don't want to strip any threads. If one won't budge, leave it sit with some penetrating oil applied. Do that a couple times a day for several days if necessary.
Also make sure and read a lot of the posts of what to remove to get to those PITA plugs.
Good luck.
Old Aug 20, 2002 | 08:29 PM
Utahvette's Avatar
Utahvette
Default Re: time to replace the plugs? (Dan Parker '96)
thanks guys, I wont be changing them anytime soon though, long way to go to hit 100k :cool:
To time to replace the plugs?
