1995 coolant temperature sender torque spec
Old Jul 28, 2015 | 05:40 AM
Christi@n's Avatar
Christi@n
Default 1995 coolant temperature sender torque spec
I've replaced coolant temperature sender, water pump, does it require a specifical torque?
At the moment i've just tight it very gently
Old Jul 28, 2015 | 05:55 AM
WW7's Avatar
WW7
Most sensors on engjnes do have torque specs, but some are more critical then others..For instance, knock sensors won't operate properly unless torqued to their specific spec..Others , like the coolant temp sensor are not as critical, but they all should still be torqued to spec if possible..This is why a FSM is a great book to have....WW
Old Jul 28, 2015 | 07:16 AM
Christi@n's Avatar
Christi@n
I know, infact I want to get a copy as soon as possible...
Any one with 1995 FSM??
Old Jul 28, 2015 | 07:46 AM
WVZR-1's Avatar
WVZR-1
Not from a '95 but a '94 and it's spec'd as 17lbft or 23Nm for the ECT to pump.
Old Jul 28, 2015 | 07:49 PM
Christi@n's Avatar
Christi@n
That should be the same
To 1995 coolant temperature sender torque spec
