ECM Upgrade for CFI
but it runs better than a 85 -89 modell right now
Reading...
THIRD GEN
I've been running that ecm for 4 years now and am very pleased with it. It allows to store up to 8 tunes at one time and is set up to allow you to expand your build at any time.
I've done lots of research in the beginning. I first did similar mods as you and used that ecm, it did also allow me to convert over to multiport when I wanted to. Now the car runs a Holley stealth ram intake. Lays down 463 ponies with a NA engine.
FWIW- 2 in TB's are useless, proven fact. Some here have tried it, and I have to.. there was no track time difference using stock size or 2 in TB's on a XRAM.. and even tho the renegade claims the 25hp gain which is nice... a properly ported intake or in my case the XRAM proved a 38hp gain.. on the dyno. Proven fact. Save your $400 and find a better place to spend it.
And i can certainly believe that just boring the throttle bodies without all the associated mods might not do much...
Just have fun with your car. I am going tk check the timing on mine. I have had two of them so far and never had an issue with how they ran. Slow? In stock form, yes. Lol but in my opinion they are all slow so I don't get hung up on it too much.
I prefer a C4 over the other years because I grew up with them.
2. Throw some decent SBC heads on it - $1,000
3. Headers - $500
4. Custom exhaust - $500 (at about any shop this is the most it should cost)
5. Nice little cam that works with the stock computer - $250
Say for all gaskets and seals and timing chain and getting your TB's done (if you can't do it) and fluid - $500
That's under 3k and some wrench time. You will have way more than 250 hp and be quite streetable as long as you don't go wacky on the compression and cam. Just exhaust and porting your intake would get you to about 250 hp. So for not a lot of money you can get to your goal. That would be what, a grand or a little more?
I didn't need the ecm until I went to the 90lb injectors.
If I had to do it all over again I would have done my mods differently knowing what I do now.
I did knock my track time down almost 2 full seconds.
My suggestion.... do your few mods, adjust your fuel pressure, adjust timing and leave it. Enjoy the car..
So maybe what I'm looking at will get me closer to 290 HP, but if it doesn't and I only get to 250 HP I will still be happy.
The 290 is based on adding the "up to" numbers... which as I said, I know not to be completely realistic... 205 stock + 20 for intake porting & TB boring & upgraded injectors + 20 for headers and exhaust + 20 for heads + 20 for cam and maybe + another 5 for roller rockers and double roller timing set...
290 would be good... competitive with a lot of lightly modded L98 cars and wouldn't get completely crushed by LT1 cars...
I only say that (in this thread and others) so that when you get it done, and you dyno 250hp (if that were to happen), then that would be a huge indicator that you have more work to do.
Dominic Sorresso on this forum did the same build you're doing, basically, except that he extrude honed his intake, rather than porting it, so IMO, he left some on the table there by not removing enough material. Anyway, his results were ~320hp, if I recall correctly. That should be your benchmark, IMO, for the money you're spending and the parts you plan on installing.
I'm old school, I ran a tunnel ram dual carb on the street in the 70's. Holley set my engine up with dual 480's they claimed it was better to run lean than rich. They physically touched my motor because I was running 650's, and they were in town at my parts house.
Bought a crossfire, the 1st thing I'm doing is y'ing the tbi's for 14lbs parallel. 2nd thing is replacing the manifold. 3rd is going to a 1:6 rocker arm.
The question is Why can not the ECM handle anything further? Too Slow?
