Can't find 89 ECM
Old Aug 20, 2002 | 02:08 PM
Austin89's Avatar
Austin89
Default Can't find 89 ECM
Need to check to make sure it's stock (installing N02).
Looked under drivers side (under instrument panel) and
passenger side (by heater core). Am I overlooking it?
Also checked above battery.
Also, where can I get an 89 specific service manual?
Thanks guys
Old Aug 20, 2002 | 04:59 PM
hotwilzz's Avatar
hotwilzz
Default Re: Can't find 89 ECM (Austin89)
its on the passenger side . remove the panel and look straight up. you should see 2 10mm nuts looking back at you along with the harness connectors. remove the 2 nuts and the ecm will slide out of the carrier
hope that helps
david
Old Aug 20, 2002 | 05:00 PM
pablocruise's Avatar
pablocruise
passenger footwell inside car, under hush panel. I think I saw a 89 service manual in the for sale section awhile back.
Old Aug 20, 2002 | 10:51 PM
Danno355's Avatar
Danno355
Bring a comfy pillow out to remove this as you'll be upside down in the footwell. Thankfully it is only two bolts. Not counting the 4 for the plastic kick panel. The retaining clips for the wire harnesses are fairly straight forward. The ones closest to the seat hold in the harness, while the others are there for leverage. When reinstalling it, you'll need to apply a little bit of force, (not a lot) to seat the rubber guide pins. Its about a 10 minute job.
Old Aug 21, 2002 | 08:30 AM
Shonan's Avatar
Shonan
Default Re: Can't find 89 ECM (Danno355)
Old Aug 21, 2002 | 08:01 PM
JonM's Avatar
JonM
Manuel = http://www.helminc.com/helm/homepage.asp?r=
Old Aug 21, 2002 | 08:32 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Pictures and instructions here:
http://home.flash.net/~marcho/1985ecm.html
1989 will be in the exact same location as my old '85, the chip inside is different though. Those pictures will guide you just fine.
:cheers:
Old Sep 2, 2002 | 09:49 PM
Austin89's Avatar
Austin89
Thanks everybody! :D
To Can't find 89 ECM
