If your thinking of installing a larger TB to increase power, forget it , unless you go over 400 hp the stock TB is plenty..I'm right around 400 hp and running the stock TB without any problems...WW
Not sure I'd agree. I bored my stock tb to 52mm. the throttle response was worth the upgrade IMO, motor has about 350-370 hp. The 52mm will accommodate future mods.
Excuseme, i don't understand very well.. 52 mm is better than 48? Even for stock engine?
I had to replace TB cause i've a problem on it... Stock engine 52mm would work fine on mine?
I'd buy a 1000cfm unit and get it over with if you are planning big mods for the future. OTOH, 52 is plenty for a stock unit. I had a friend that told me on back to back runs, he lost time by going to the 1000cfm unit ONLY. My thought is that without supporting mods, you could create a problem. I changed intakes and added headers and that was what Lingenfelter had at the time and what I had him tune for. Now that I have a 383 making about 420 at the wheels, I would think it is ok.
52mm ot 58mm is the only unit available as brand new part, 48mm is no longer available, just used??
