Transmission Transfusion
Old Aug 20, 2002 | 03:34 PM
gbody5's Avatar
gbody5
Default Transmission Transfusion
Can't find a place that changes tranny fluid anymore, they all do the full fluid transfusion process. Pro's / Con's?
Old Aug 20, 2002 | 04:05 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default Re: Transmission Transfusion (gbody5)
:confused: :confused: :confused:
Now I'm real confused, every one wanted to just change my fluid and filter. I had to look around for some one with a T-tech machine to transfuse mine.
It only needs to be transfused once in a long while. Mine had 120K when I did it. I'll do it again at 210K. Regular fluid and filter changes will depend on how much I drive it. < 12K a year I'll change every other year unless I start road racing it. > 12K or significant road racing then once per year.
Old Aug 20, 2002 | 04:07 PM
Rick86's Avatar
Rick86
Pros:
They change all of the fuild
Cons:
Most shops will not change the filter.
Old Aug 20, 2002 | 05:19 PM
gbody5's Avatar
gbody5
Default Re: Transmission Transfusion (Rick86)
The filter, that's what I was afraid of when I read the description. I like the idea of getting all the fluid out and all new fluid in, but I don't like the idea of not changing the filter.
I have close to 50k miles on the car and I don't think it has ever been changed, so that's why I'm looking into it.
Old Aug 20, 2002 | 05:35 PM
OleDog's Avatar
OleDog
Do both the flush and the filter change yourself.
If you get someone to drop the pan and the filter that changes about 4+ quarts. The flush changes 11 1/2 quarts.
I flushed mine(very easy, search for the post ). My car is up on jackstands right now when I get home I'm dropping the pan and changing the filter.
PS last night I loosened a couple of bolts to start the draining process, I always seem to make a mess.
Old Aug 20, 2002 | 07:03 PM
old salt's Avatar
old salt
i avoid the tranny pan drop for my filter change. i bought a oil filter relocation kit. first i pulled the pan and welded a drainplug fitting(similar to the one in the oil pan)you gut the filter element in the pan filter, then i installed the filter kit on my transmission line. i use the filters that are for a saturn transmission. when it is time i open the drain and change the filter. just like the oil. and i always use syn. trans fluid. just an idea but it makes trans maint. a short job.
To Transmission Transfusion
