U Joint Coating necessary?
Old Aug 5, 2015 | 08:38 AM
rimo's Avatar
rimo
Default U Joint Coating necessary?
I am about to put new u joints in my 1995 automatic coupe and would like to get Spicers. The aluminum shaft, non-corrosion coated u joints are the part number 5-3615x, but they are about $60 a piece. The aluminum shaft, non-coated u joints are the part number 5-1350x.
I've read countless threads on u joint part numbers, but I haven't really seen too much about if the non-corrosion coating is absolutely necessary. I live in Alabama and drive my car year round, but we very rarely see snow in the winter, so is the coating necessary or will I be fine with the 5-1350x?
Old Aug 5, 2015 | 09:31 AM
antfarmer2's Avatar
antfarmer2
I would use the coated ones some have used antiziese
Old Aug 5, 2015 | 10:19 AM
John A. Marker's Avatar
John A. Marker
The coated joints are the way to go. You will have a galvanic corrosion reaction with a non-coated joint. If your going to use the non-coated joint then use anti-seize on the outside of the caps.
I am sure you have heard multiple stories here about bolts breaking off in the aluminum...most often intake manifolds. This is the galvanic corrosion between the steel bolt and the aluminum.
To U Joint Coating necessary?
