Rear differential
Old Aug 9, 2015 | 12:35 PM
Corvette72151's Avatar
Corvette72151
Navigator
Default Rear differential
Can someone tell me how difficult it is to change the gear carrier in my 91. In thinking of going to 3:07 to give it a little more performance. Did the trans myself with no lift or trans. Jack. Very capable mechanic but never did. C4 rear. Thanks guys.
Old Aug 9, 2015 | 12:44 PM
ex-x-fire's Avatar
ex-x-fire
If it's a Dana36 why not find a used one.
If you handled a trans swap you should be able to swap out the diff. Setting up a set of gears requires much more experience.
Old Aug 9, 2015 | 01:25 PM
Corvette72151
Navigator
Default Rear end.
No I don't want to change the gears only In planning on a used carrier. I just wanted to know how difficult it is to just change the carrier. Thanks again.
Old Aug 9, 2015 | 02:15 PM
l98tpi's Avatar
l98tpi
Max G’s
It is not very difficult to change the carrier. The biggest pita is getting the rear back in. An extra set of hands are nice. Also you want to update your u-joints too since all is disconnected. If you have a FSM, you will have all you need as far as the procedure. The 3.07 is a very nice upgrade.
Old Aug 9, 2015 | 02:21 PM
Vic'89's Avatar
Vic'89
It's not that difficult in swapping rears.
I did mine on jack stands in the driveway.
the most difficult part is unbolting the C beam from the Diff.
Those 2 bolts on top of the C beam require a wrench on them to they don't spin with you unbolt from the bottom.
Vic
Old Aug 9, 2015 | 03:02 PM
ex-x-fire's Avatar
ex-x-fire
Ok, just so we know we're on the same page.
1st picture is a carrier.
2nd picture is a differential housing. It not called a carrier.
To Rear differential
