I recently just had my optispark replaced, my horn worked fine when i took it to the garage, my sticker was dead, and when i asked them to put a new sticker on, and he wouldnt because of the horn, so i go pick it up, drive it home and start replacing fuses and relays, i cant figure it out. When i press the button i hear the relay clicking. Any help and suggestions?
See if they knocked the wire off the horn. Jump a wire and make sure the horn works might be bad.
I went out yesterday to check everything out, replaced a blown fuse on the bottom of the horn and still nothing. keeps clicking in the relay. how would i jump the a wire to the horn, i dont really want to cut any wires or anything. i had an 86 that i had to jumpthe horn and my 93 is a different set up.
Just run 12volts to it from the battery or battery charger. Or just use some jumper cables with a piece of wire.
