What exactly does the A.I.R. pump do?
Old Aug 21, 2002 | 01:58 AM
Stevmill's Avatar
Stevmill
Default What exactly does the A.I.R. pump do?
And why do I need it.:confused: I assume it has to do with smog. I live in California, and was wondering if I can remove it and still pass.
Old Aug 21, 2002 | 02:09 AM
vettl83's Avatar
vettl83
Default Re: What exactly does the A.I.R. pump do? (Stevmill)
Your right it does have to do with emissions. Do you need it, probably in California. What does it do, basically it pumps fresh air into the exhaust system. Will the car run ok without it, no problemo. Good luck 84 CF 91 ZR-1 #2039
Old Aug 21, 2002 | 02:11 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The AIR pump through the diverter valve provides air into the exhast manifold during warmup to reduce emissions and quickly heat the O2 sensor so the ECM can enter closed loop mode. After warmup the diverter switches air flow into the cat, under some conditions; otherwise it is dumpped to the atmosphere.
Technically you could replace the O2 sensor with a heated unit and replace the stock cat with a more efficient new one and eliminate the AIR apparatus with cleaner emissions.
However, as you live in beautiful CA, the smog police will likely nail you on the visual test.
Old Aug 21, 2002 | 02:12 AM
C4-Wolf's Avatar
C4-Wolf
It pumps air into the exhaust lines in front of the pre-cats and the main cat. This helps heat up the cats and thus helps burn off excess fuel and other things escaping into the atmosphere. As far as I know Cali. is pretty strict in most places as far as altering your emissions equiptment. I don't think it would be a great idea to get rid of it as you probably won't pass a visual inspection.
Old Aug 21, 2002 | 03:01 AM
Stevmill's Avatar
Stevmill
Default Re: What exactly does the A.I.R. pump do? (65Z01)
So, it sounds like if removed, the emission levels should be OK, right?
As for the visual test, how many other cars have these? I haven't seen one before or after the Vette. Do they have some sort of guide telling them what to look for? :confused:
Old Aug 21, 2002 | 05:11 AM
Cratzy's Avatar
Cratzy
I have "race" cats on my car, without the air line plugged in - no problems with emission. I still have the air pump left though, pumping air into my headers.
Old Aug 21, 2002 | 11:08 AM
KyleBst264's Avatar
KyleBst264
All an A.I.R. pump does is rob horsepower. I believe a.i.r. pump eliminator kits are available.
Old Aug 21, 2002 | 02:28 PM
lead_foot's Avatar
lead_foot
Default Re: What exactly does the A.I.R. pump do? (KyleBst264)
ttt
Who sells the elimination kits?
Old Aug 21, 2002 | 02:48 PM
Tom73's Avatar
Tom73
If you remove the A.I.R. pump it will allow raw and unburnt fuel to exit the exhaust system they raising the emissions of the car. By putting air into the exhaust manifold it helps complete the combustion process and make sure all the fuel is burnt.
Your emission label on the car states what is to be on the car. If it is missing they have reference books.
You can buy eliminator kits from most Vette vendors such as Ecklers or Mid-America. Here is the one from ZIP, $159:
tom...
[Modified by Tom73, 12:54 PM 8/21/2002]
Old Aug 22, 2002 | 04:31 AM
Stevmill's Avatar
Stevmill
Default Re: What exactly does the A.I.R. pump do? (Tom73)
Yeah, I saw the kit, that was what got me to thinking about removing it. I wanted to clean up the engine area, plus get a few HP back. If removed will it add a lot to the emissions? I guess I am asking if I find a "friendly":rolleyes: shop to do the test (at least on the visual part, do you still think it will pass the actual emissions test? I was thinking of doing this after I get a ZZ4 short block in.
Old Aug 22, 2002 | 08:57 AM
Tom73's Avatar
Tom73
Removing it will give you more HP and it will add to the emissions. Would depend upon finding a testing station that would pass it with the pump gone. Gain in HP? Does not take much to turn that pump. Maybe gain 3 hp, not enough to feel. So is the hp gain worth the emission testing hassle?
tom...
To What exactly does the A.I.R. pump do?
