1990 Driver Power Window Problems
Old Aug 11, 2015 | 01:48 PM
Taurusp3's Avatar
Taurusp3
1st Gear
Default 1990 Driver Power Window Problems
-Replaced motor
-Replaced Switch
-Window works when it wants to, but maybe only an inch or two.
-12 volts at window motor connector
-worked before I installed it and regulator back in door.
-worked for a little bit after installed
What am I missing?
Could it be a ground issue?
Fuse issue?
Breaker issue?
