Water pump drive gear
Old Aug 21, 2002 | 08:14 AM
ericcer's Avatar
ericcer
Default Water pump drive gear
I am about to to the Electric water pump conversion and noticed in the manual that you need a puller for this drive gear. It that true or necessary?
Maybe I can remove it any way I can without worrying about damaging it because I am not going to reuse it?
Old Aug 21, 2002 | 10:49 AM
tdock's Avatar
tdock
Default Re: Water pump drive gear (ericcer)
If your intake is off, I tapped mine out with a rubber mallet and socket extension (gently). Sprocket puller might work if you can get it behind the gear and the block but it's pretty tight.
