does a holley stealthram fit a c4?
Old Aug 21, 2002 | 08:43 AM
gtsyellow's Avatar
gtsyellow
Default does a holley stealthram fit a c4?
any clearance issues? things look tall in pics but man the price of them is great, i have a feeling TPIS will be loosing a few miniram sales. i wanna get one of those things if i can make it fit. anyone know if they do?
Old Aug 21, 2002 | 09:24 AM
TA's Avatar
TA
Default Re: does a holley stealthram fit a c4? (gtsyellow)
Someone has tried this on the forum and the stealth ram would not fit under the stock hood. He posted pics and I believe the hood came about an inch or two from closing.
Old Aug 21, 2002 | 10:17 AM
MrJay's Avatar
MrJay
The Stealth Ram is to tall it is 1 inc to tall you will not be able to close your hood.
Grumpyvette has it on his vette and he just loves it to it was to tall he had to get a different hood.
Jay
Old Aug 21, 2002 | 12:16 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
there is one on ebay for $500.00 buy it now! :yesnod:
Old Aug 21, 2002 | 02:26 PM
vader86's Avatar
vader86
It wont fit under the stock hood.
Old Aug 21, 2002 | 06:41 PM
gtsyellow's Avatar
gtsyellow
Default Re: does a holley stealthram fit a c4? (vader86)
damn !!!!!!!! :boxing
Old Aug 22, 2002 | 10:14 AM
350camaro's Avatar
350camaro
Default Re: does a holley stealthram fit a c4? (MrJay)
What hood did grumpyvette use for the stealth ram?
Old Aug 22, 2002 | 11:29 AM
MrJay's Avatar
MrJay
350camaro I was just told that he did not change the hood he put on a hood scoop I dont know what kind he got.
Jay
Old Aug 23, 2002 | 11:19 AM
damionvoss's Avatar
damionvoss
Does anyone know where he got the hood scoop? Or is it possible to modify the StealthRam to fit?
Old Aug 23, 2002 | 12:17 PM
MrJay's Avatar
MrJay
Sorry dont know what kind of hood scoop he got, just do a search on Stealth Ram and I think you will see all the posts that he has on it.
I would think you could make a Stealth Ram fit by working on it but since I dont have one or have seen one I dont know how much work it would take.
I want to get one and see if I can do it, but that will have to waite.
Jay
Old Aug 23, 2002 | 12:20 PM
damionvoss's Avatar
damionvoss
I was thinking the same thing. I have a buddy who owns a machine shop, so I could definitely experiment on one...I'm just worried about changing the flow capabilities of the intake.
Old Aug 23, 2002 | 04:12 PM
want2drivemy85's Avatar
want2drivemy85
Default Re: does a holley stealthram fit a c4? (damionvoss)
does anyone know what the difference in height is between the stock tpi and the stealth ram? Surely it can be modified to work if you really wanted it to!
Old Aug 23, 2002 | 04:34 PM
DADDY D's Avatar
DADDY D
Default Re: does a holley stealthram fit a c4? (want2drivemy85)
i heard it is 2 inches taller than the stock tpi that what the tech from thundre racing told me
Old Aug 23, 2002 | 06:03 PM
MrJay's Avatar
MrJay
I was told that it was under a inch there are some pics on here that show them next to each other and it is not that much.
Jay
Old Aug 23, 2002 | 06:11 PM
Raistlin's Avatar
Raistlin
u can get a new plenum made for it that is shorter, but, if i had the resoureces, i would do a combination of shortening the runner length (shaving down the top where it bolts to the plenum) u have a limited amount of material u can remove because of the fuel rails, 1/4 inch or so, and put a shorter, and maybe wider plenum.
there is someone online that modifies the stealth ram plenum to fit. i don't have the info, but it is in Grumpy's post on pictures of the stealth ram install
Old Aug 23, 2002 | 07:44 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
I and Anguish have been kicking the idea around to use the TPI plenum. Just bolt some plates over the openings, machine the holes for the plenum. Bolt it on. The stock plenum is shorter and has all the holes for the TB and throttle linkages. Another option is to use another Holley fi intake and get a square alumnum box like an explosion proof junction box and machine that to fit.
The plenum part really only needs to be a box that the throttle body and linkages a bolt to and will not blow apart if the engine back fires. No tricky engineering here.
To does a holley stealthram fit a c4?
