Clearing history codes
Old Aug 12, 2015 | 10:35 AM
9T3VETTE's Avatar
9T3VETTE
Default Clearing history codes
Is there a specific way to clear history codes?
My service ride control light is on, however I only have a history codes.
- Module 1: c12
- Module 4: H44 (lean o2 sensor)
- Module 9: H72 (serial data failure)
A vacuum leak was found so the lean condition should be fixed, but I have not figured out why H72 is set. Disconnecting the battery doesn't seem to clear the history codes.
Old Aug 12, 2015 | 10:41 AM
antfarmer2's Avatar
antfarmer2
Go to autozone they can hook it up to a scanner they cannot clear the codes but will turn their head while you push the button.
Old Aug 12, 2015 | 10:46 AM
WVZR-1's Avatar
WVZR-1
I doubt for his OBD1 car but maybe. The AZ here I believe has OBD2 capable scanning devices. I've been told that and have never asked. I interpreted from the OP's user ID it was likely an OBD1 car. Maybe I missed something?
Module 9 is ABS/ASR? I don't believe AZ can do that for any. If it is actually module 9 and the clearing doesn't work using the DIC procedure and you don't have an ABS/ASR IND light - why be concerned? It's history.
RIDE CONTROL isn't diagnosed in or by the DIC and that requires a completely different procedure.
Old Aug 12, 2015 | 11:07 AM
THE 383 admiral's Avatar
THE 383 admiral
The chain parts stores do not support OBD1 cars. Pulling the Battery cables will clear out the code/s.
Old Aug 12, 2015 | 12:47 PM
antfarmer2's Avatar
antfarmer2
They do by me one horse town.
Old Aug 12, 2015 | 12:51 PM
pifo1964's Avatar
pifo1964
With the paper clip jumping A and G in the ALDL, try this:
When the codes sequence ends, press the TRIP RESET button until 4.0 is displayed in the module number area. Then press the TRIP/ODO button until 4.7 is displayed in the module number area. Press and hold the ENG/MET button until “—“ is displayed. This will clear any ECM codes.
Then press the TRIP RESET button until 9.0 is displayed in the module number area. Press the TRIP/ODO button until “9.7″ is displayed in the module number area. Press and hold the ENG/MET button until “—“ is displayed. This will clear any ABS/ASR codes.
Turn the key off, wait ten seconds, turn the key back on and check for any codes.
Old Aug 12, 2015 | 01:48 PM
9T3VETTE's Avatar
9T3VETTE
Pulling the battery cable did not reset the history codes, tried that several times. Autozone? I would trust those guys to even hook up a scanner to my car....
WVZR, thanks....I found the procedure on how to pull SRC codes. Basically grounding pin C on the ALDL and counting the flashes of the SRC light.
Pifo, i'll try this when I get home from work later thanks for your help!
Old Aug 13, 2015 | 05:57 AM
CRUSIN1's Avatar
CRUSIN1
check out this web site on C4 Diagnostic trouble codes...
http://tech.corvettecentral.com/2011...trouble-codes/
Old Aug 13, 2015 | 10:46 AM
85BK86's Avatar
85BK86
Cruising
Try O'reilly's. They had an OBD1 scanner, and believe it or not, seemed to know what they were doing with it! I hate most chain stores, but O'reilly's does alright by me.
They were unable to clear any codes though. The scanner said something about requiring a specific procedure involving a fuse. I checked online, but couldn't seem to find what it was talking about.
From what I've researched, just disconnecting the battery for at least 10 seconds should do the trick. I'm interested to see what you find. Good luck!
Old Aug 13, 2015 | 11:37 AM
TorchTarga94's Avatar
TorchTarga94
This works. Atleast it did for my 94'.
Old Aug 13, 2015 | 01:14 PM
9T3VETTE's Avatar
9T3VETTE
Thanks to the forum, the codes are cleared. Pifo's method worked flawlessly and honestly I should have read the FSM more carefully, it was in there.
SRC was diagnosed to be:
-code 23 (loss of speed singal) which is triggered by the key being cycled on/off 3 times with no start.
- code 31 (left front out of position).
I'll dive into 31 when I get some time, but at least it's running good in the meantime
Old Aug 13, 2015 | 01:36 PM
pifo1964's Avatar
pifo1964
Old Aug 13, 2015 | 10:32 PM
85BK86's Avatar
85BK86
Cruising
Is this method good for all C4s, or only certain years/models?
Old Aug 14, 2015 | 09:28 AM
pifo1964's Avatar
pifo1964
Jumping A and G is only for 1990-1993
For later C4 corvettes, I think you can delete codes the same way but not sure which conectors to jump in the ALDL
Old Aug 15, 2015 | 10:56 AM
85BK86's Avatar
85BK86
Cruising
Good to know! Thanks for all the useful info...
Old Aug 15, 2015 | 11:07 AM
WVZR-1's Avatar
WVZR-1
Don't just randomly start "jumping things" or attempting anything that you've only read and maybe wasn't mentioned to be MY applicable.
MY - Model Year
WAG's can get you much deeper than you likely are
WAG - Wild A$$'d Guess
Old Aug 15, 2015 | 07:09 PM
Christi@n's Avatar
Christi@n
- Module 1: c12
It is possible, in my 1995 with obdII plug, just with paper clip and pressing right buttons, i would assume, even your should be.. Which year?
To Clearing history codes
