I'm using the aldl droid app with 1320 electronics bluetooth. My car is running like **** once it gets up to temp and I let it sit for 15 minutes or more. Wanting to see if my datalog can help, but I doubt it's giving me accurate info with the "chcksum mismatch" message. Has anyone had this problem, how did you fix it?
I get a checksum intermittently on my 90 using aldldroid, it has to do that the data comes through the CCM first instead of directly from the ECM. It does not seem to effect data ecept it gives the incorrect oil temp witch has to do with the adx file. You can try posting over on the EFI gearhead forums, they have a thread covering aldldroid which I believe the developer is involved with.
Awesome read Ok thanks, I thought something was wrong. So guys, how would I know if my o2's are bad? On this app, it gives me a temp readout for both sensors.
On my 90 there is only one 02 sensor and I beleive it reads in millivolts, once your in closed loop the 02 should bounce around from say 30 to 800, from what I have learned so far that tells you they are working, on your 93 you may have heated 02 senors, but I would think you should have the same readings on your 02's in millivolts.
Did 3 datalog files today. One with a cold start. Second with engine warm and a WOT pull. 3rd when I felt the miss. How do I upload them to the forum? Or I can email them to someone if you want. Any help is appreciated
