Need help with 1990 with terrible miss
Old Aug 21, 2002 | 11:42 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Need help with 1990 with terrible miss
Hi Folks,
I have a friend with a 1990 that has me stumped and I need your help BADLY! All was good until he got on the gas. He says he got on the throttle hard and it started to run like crap. It idles rough like he has a miss and stays that way throughout the driving range. Codes 21 and 34 popped up. I thought maybe he needs a prom upgrade due to his mods but he reminded me that it was running fine before. It just happened all of a sudden.
He's done plugs, wires, cap, rotor and fuel filter and has not cleared the problem. We tested the TPS and get no reading. We even checked a few other TPS's that I have in my little Dr. bag and none of them had a reading. He tested the wire from the TPS to the ECM and it checks OK. I checked all the vacuum lines and everything appears to be fine. Nothing seems to be unplugged. No codes have stored since the original ones were erased.
What else should we look for? Any help would be very appreciated! :blueangel:
-John
Old Aug 21, 2002 | 12:36 PM
65Z01's Avatar
65Z01
Default Re: Need help with 1990 with terrible miss (War Machine)
The Code 21 (TPS too high when air flow is less than 15gm/sec) combined with Code 34 (MAP signal too high when TPS greater than 1.5Vdc) might point to a bad MAP sensor.
A scan tool would tell the story.
Old Aug 21, 2002 | 12:59 PM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Make sure that the bolt that holds the distributor from turning is tight. If the bolt loose and you get on the gas hard it can turn a little at a time and you know the rest of the story.
Old Aug 21, 2002 | 01:33 PM
War Machine
Default (65Z01)
Thanks! We'll check into that. :)
joecaver, we haven't done the timing yet due to the TPS reading 0.00. Will we still be able to accurately set the timing like that?
Old Aug 21, 2002 | 06:51 PM
gtsyellow's Avatar
gtsyellow
Default Re: (65Z01) (War Machine)
corvette0096 has a spare map sensor if you need one, also keep an eye on your plug wires, more misfires come from leaky wires that are gummed up with oil
Old Aug 22, 2002 | 10:59 AM
War Machine
Thanks again for the help. Well here's an update. We set the timing, checked the TPS again and the MAP, both seem to be fine. I think his code 21 is from that silly throttle performance switch. :crazy: We decided to change out the ECM and it ran worse. We're beginning to think it's the fuel pump by the way it was bucking back and forth. I don't really know what a failing fuel pump is like on a C4 so I could be wrong.
Old Aug 29, 2002 | 11:32 AM
War Machine
Default Re: (War Machine)
Thanks for the suggestions! :cheers:
It turned out to be one fuel injector stuck open. Also it is that doggone throttle performance switch that set a code 21. I really wish the parts folks would stop selling that thing. :mad
To Need help with 1990 with terrible miss
