Need rear end info.
Old Aug 21, 2002 | 12:34 PM
champs_97's Avatar
champs_97
Default Need rear end info.
Trying to decide which gears would be best for my 85' auto. Any suggestions? How do I find out what I have in there now?
Old Aug 21, 2002 | 12:54 PM
mfranco's Avatar
mfranco
Default Re: Need rear end info. (champs_97)
If you do a search in the past topics you will find more than enough info to answer your questions.
Old Aug 21, 2002 | 01:56 PM
STL94LT1's Avatar
STL94LT1
3.07 on mostly stock engine. 3.54 on modded engine heads/cam/intake.
Old Aug 21, 2002 | 01:58 PM
vader86's Avatar
vader86
Look in your RPO codes for a code that starts with G, usually something like GM3, GM1, G92, etc. And post it here and someone will tell you.
Or, what rpm are you turning at 70mph, my automatic with 3.07s runs 2000rpm at 70.
3.07 is the best gear for the L98. If you change to a miniram, then something like 3.54, 3.73 would be an option.
[Modified by vader86, 12:59 PM 8/21/2002]
To Need rear end info.
