What is this - 1994 Corvette
Old Aug 14, 2015 | 11:11 PM
John A. Marker's Avatar
John A. Marker
Default What is this - 1994 Corvette
Tying to my other thread....1994 Corvette
https://www.corvetteforum.com/forums...o-problem.html
What is this part? Part is about 1x1x1-1/4". Three wires into this part only on the end showing in the picture. No other wires in or out. Black wire in is grounded to the block, large white wire is from the coil and smaller white wire goes into the loom toward the PCM. This part is not shown in the electrical diagram.
Old Aug 15, 2015 | 03:19 AM
Crash594's Avatar
Crash594
My only guess would be a noise filter for the tac. Just a guess
Old Aug 15, 2015 | 04:24 AM
WVZR-1's Avatar
WVZR-1
"Crash594" did well - It is the tach filter and it should be in the FSM 8A-20-1 and referenced again in the cluster diagram that will direct you back to the
Old Aug 15, 2015 | 07:13 PM
Christi@n's Avatar
Christi@n
Where's located? Serms to be over coil, tb right side
Old Aug 15, 2015 | 07:29 PM
John A. Marker
It is right next to the coil on the passenger's side front.
Old Aug 16, 2015 | 05:23 AM
Christi@n's Avatar
Christi@n
Mine 1995, think not fitted with, just i will take a look later, I'll let you know
Old Aug 16, 2015 | 01:41 PM
John A. Marker
I also have a 95, but it is in the shop for new clutch and other work. So can't look at mine. Her's is 94. Find it interesting that this is hardwired into the electrical system.
Old Aug 16, 2015 | 04:49 PM
Christi@n's Avatar
Christi@n
Confirm that mine is without it
Old Aug 17, 2015 | 11:08 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
These guys "got it".
Old Aug 17, 2015 | 12:44 PM
Christi@n's Avatar
Christi@n
Tach filter what is? Tacometer filter
Old Aug 18, 2015 | 03:57 PM
TorchTarga94's Avatar
TorchTarga94
That is for sure the tach filter. Helps produce a clean signal for the tach to display on the cluster. 95-96' models I don't believe have a tach filter, the feature is utilized within the PCM itself.
To What is this - 1994 Corvette
