idle question
Old Aug 21, 2002 | 01:05 PM
flubuyu2's Avatar
flubuyu2
Default idle question
hello,I replaced the vac. lines from the throttle body to the carbon canister "switch"and from the "switch"to the canister also replaced the vac. line on the pcv...that's all I did and the idle seems to be sticking @ about 11-1200 till I punch the gas when stopped then she idles down to normal ? Anyone else have sim. problem ...any sugg.s on how to fix ? :confused:
Old Aug 21, 2002 | 01:43 PM
LarryK 87's Avatar
LarryK 87
Default Re: idle question (flubuyu2)
check your throttle linkage where it enters the TB, apperantly this is a common problem ( have seen more than a few posts about that ), you can try a bit of lubricant
Old Aug 21, 2002 | 03:16 PM
flubuyu2's Avatar
flubuyu2
Default Re: idle question (LarryK 87)
that's one thing I haven't checked !
Thanx :cool:
To idle question
