Underdrive pully Bouncing??? Weird?
Old Aug 21, 2002 | 01:27 PM
krivera's Avatar
krivera
Default Underdrive pully Bouncing??? Weird?
Ok....i am at lunch today and i looking at my charger and tensioner and i notice my tensioner bouncing?? so i look deeper and see my bottom underdrive pulley (crank) bouncing or it looks like it is loose? so i reached down and pulled on it up and down and it seemed solid but it is hard to tell? But what could cause this besides it being loose? is it possible to have the crank bounce??? i am not familiar with building a small block?
Old Aug 21, 2002 | 03:14 PM
gcrouse's Avatar
gcrouse
Default Re: Underdrive pully Bouncing??? Weird? (krivera)
Tensioner bouncing around a little is normal. So is your crank pulley going up and down at regular intervals, like the pulley is bent or not fully seated on the dampener. Can you see the crank bolt in the center and tell if it's moving? Is the dampener moving around too? Does the engine seem at all unbalanced?
Also- how rough is your idle? it's not just the whole motor moving in the mounts is it?
Old Aug 21, 2002 | 03:37 PM
BaseballDude's Avatar
BaseballDude
Default Re: Underdrive pully Bouncing??? Weird? (gcrouse)
Possible dampener failure settling in...... :eek:
Old Aug 22, 2002 | 03:15 AM
bill mcdonald's Avatar
bill mcdonald
You have an underdrive pulley on your main crank with a supercharger?
I would have to go with the pulley is not seated all the way as well, or it is bent as well.
Old Aug 22, 2002 | 02:30 PM
krivera's Avatar
krivera
Default Re: Underdrive pully Bouncing??? Weird? (bill mcdonald)
well i dont have a smaller pulley on the crank it is the stock one...But it reminds me of lets say a lose pulley or something? But when i look at the timing meter (when setting the timine at TDC) the balancer seems to say to spin fine (no bouncing) but the pulley bolted to that seems it moves up and down? but i thought i would get your guy opinion:D thank let me know if you guys think of something else and i will take that pulley off this weekend and check it!
Old Aug 22, 2002 | 04:25 PM
bill mcdonald
I think it is bent. I wonder if the blower could of yanked on it? or if someone else did something to it....
Does it look like it rolls in towards the motor, then out towards the radiator?
Old Aug 23, 2002 | 03:19 AM
gcrouse's Avatar
gcrouse
Definitely the pulley is bent or somehow not bolted down securely. Hey at least your balancer, crank snout, and forward main bearings are ok!
Old Aug 23, 2002 | 12:15 PM
krivera's Avatar
krivera
Yeah the balancer spins nice and smooth... it kinda reminds me of a bent rim and it is a wonder i have not thrown a belt when i put the smack down on those Stangs :D
To Underdrive pully Bouncing??? Weird?
