84 Vette starting problem
Old Aug 16, 2015 | 09:20 AM
carnutt94's Avatar
carnutt94
Default 84 Vette starting problem
I have an 84 vette (74k) that had a starting problem after it has been run a while.... It lost spark.....after sitting a while and it cooled down it would fire back up....didn't do this all the time....just when it felt like it. Replaced coil and ign module in dist (Accel) and always seems to fire up now....BUT after it warms up it won't fire in crank position but when you release the key to run position it fires up. I can crank it for 15 sec and won't fire until in run position...can also just barely touch crank position with key and be running.... Any suggestions ??? I was told to replace the ign switch on steering column...Any help would be appreciated... Thanks, Al..aka carnutt 94
Old Aug 16, 2015 | 10:18 AM
antfarmer2's Avatar
antfarmer2
It could be but did you put heat sink paste on the icm?
Old Aug 16, 2015 | 10:34 AM
carnutt94's Avatar
carnutt94
yes I did
Old Aug 16, 2015 | 10:43 AM
antfarmer2's Avatar
antfarmer2
Check and clean all fuses and grounds. How does your ing feel?
Old Aug 16, 2015 | 10:53 AM
WVZR-1's Avatar
WVZR-1
You don't necessarily need a new ignition switch but maybe just an "adjustment" of the switch. The switch is mounted to the column with screws through an elongated mounting bracket. It is NOT uncommon for the switch to require adjustment. Could you need new? Certainly. You would also want to inspect the switch electrical connecters (there are two) while you're there.
The "no crank" when hot is a separate issue and with your miles and if it's an OE starter that problem doesn't surprise me. The coil and module were likely not needed but maybe good maintenance and if you say it helped then there's no argue.
Old Aug 16, 2015 | 11:02 AM
carnutt94's Avatar
carnutt94
it runs strong...no missfires or hick-ups....when it starts...
Old Aug 16, 2015 | 11:08 AM
WVZR-1's Avatar
WVZR-1
You DO NOT have a fuse or ground issue. Is cleaning grounds good maintenance? Yes - but certainly not required for the issues you mention. Your coil and module replacement has no relationship to your current issues.
Do you have an FSM?
GOOGLE - GM column mounted ignition switch adjustment and I would expect results. I didn't look and won't.
Ignition switch adjustment hasn't changed since GM started using the column mounted key/cylinder in '69. Adjustment will be in any FSM that you have
Old Aug 16, 2015 | 11:24 AM
antfarmer2's Avatar
antfarmer2
Does the pump come on for two seconds when you turn the key to on without starting?
Old Aug 16, 2015 | 11:42 AM
carnutt94's Avatar
carnutt94
Never thought about doing an adjustment and will inspect connectors ...but why would it fire when cold but not after it reaches operating temp...never got hot..always norm temps. Always cranked over, just not fire when warm while in start (crank) position...but fire as soon as you release key to run position ????
Old Aug 16, 2015 | 11:43 AM
carnutt94's Avatar
carnutt94
yes and also new pump. I know it is an ignition issue as I have put a timing light on it and get no indication of spark when it is doing this.
Old Aug 16, 2015 | 12:00 PM
antfarmer2's Avatar
antfarmer2
Sounds like WVZR-1 got it.
To 84 Vette starting problem
