Gas tank questions
Old Aug 18, 2015 | 10:01 PM
bbwool42's Avatar
bbwool42
Default Gas tank questions
I have a 1996 C4 and fuel injector issues. I am concerned if my gas tank is rusted. But I have had difficulty learning if my tank is made of metal or fiberglass. Do the tanks become eroded? Any help appreciated. Thanks R Woolley
Old Aug 18, 2015 | 10:16 PM
antfarmer2's Avatar
antfarmer2
Just take off the fuel door then the apron and pull the pump and see best to run the gas down if you can. And yes they crud up.
Old Aug 18, 2015 | 11:16 PM
Cliff Harris's Avatar
Cliff Harris
The tank is steel and can rust.
Take out the fuel level sending unit, as antfarmer2 suggested. That will tell you a lot about the condition of your fuel tank. It's pretty easy to do. A Torx bit to get the fuel lid off and a 10mm socket for the fuel level sender bolts. Get a new gasket before you take it apart, as it will probably break if it's the first time it is taken apart.
Old Aug 19, 2015 | 11:34 PM
383tpimachine's Avatar
383tpimachine
My 85 had quite a bit of rust but I am in a high humidity area.
Old Aug 20, 2015 | 10:32 AM
THE 383 admiral's Avatar
THE 383 admiral
The C4 Tanks are made of VERY thin steel. I would remove your spare tire & storage tray. I highly recommend inspecting the tank. I have experienced small pin holes just big enough to smell fuel and create condensation. In 2 of my previously owned C4's and my current. I simply used S.S. scrub pads. Cleaned the area. Then patched with 5min Epoxy Putty. Problem solved...
To Gas tank questions
