Brake upgrade.
Old Aug 21, 2015 | 01:27 PM
TLS_Addict's Avatar
TLS_Addict
Where is the best place to order?
Old Aug 21, 2015 | 10:06 PM
93Rubie's Avatar
93Rubie
Rockauto.com is good for a lot of things might check that out.
I like to use http://www.stranoparts.com/ when I can. You won't beat his prices. He may not list stuff on his site but he can get it without any issues. Technical advice is likely better than anywhere else. He is also a Corvette Forum vendor I do believe.
Old Aug 21, 2015 | 10:44 PM
TLS_Addict's Avatar
TLS_Addict
So I am going to go with the J55 and use those till my skills improve.
For shocks I'm going to get Bilstein Sports or QA1's. Possibly sway bars.
Getting excited to turn some wrenches on this old girl.
Old Aug 22, 2015 | 10:32 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Change fluid to dot 4, centric premium rotors and Carbotech XP10 front XP8 rear pads you will have plenty of stopping power and can be driven on the street with no issues.
If interested in Carbotech pads I will be happy to help you.
XP10 $199 XP8 $153
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Aug 22, 2015 | 05:29 PM
LSWONGTO's Avatar
LSWONGTO
When I can without pissing off my wife, I want to get the Addco sways and the master poly bushing set. Just doing the Hawk Pads & Stainless lines with new Dot 4 fluid is a great upgrade for the money. Also I read that the 95-96 come standard with J-55 brakes, is that correct?
Old Aug 22, 2015 | 05:31 PM
TLS_Addict's Avatar
TLS_Addict
Yes, that is true.
Sounds like some good mods! Just tell the wife to "Know her role." Lol
Old Aug 22, 2015 | 08:12 PM
93Rubie's Avatar
93Rubie
FYI, the Bilsteins should be a good shock. QA1 makes a nice drag racing shock. Ridetech makes a REALLY nice double adjustable. Koni's Sport shock single adjustable cannot be beat for the price. I got my set for about $600.
What Adam@carbotech said is all you really need as far as brakes go.
Old Aug 23, 2015 | 09:31 PM
l98tpi's Avatar
l98tpi
Max G’s
Koni yellows are great for starting out and you havesome adjustment. Hawk makes a new Street/Track pad that might be best for you. Motul 600 or Castrol SKF for the brake fluid. J55's slotted rotors would be my pick.
Old Aug 28, 2015 | 02:53 PM
Ripe93's Avatar
Ripe93
Cruising
On a budget here so I just went with some Hawk pads and some Castrol SRF in my Motive Power Bleeder and I was down the road! Quite noticeable and not so much brake dust after a bit of 'spirited' driving.
