No start after new timing chain
if the timing sprocket marks are aligned, #6 should be at TDC (compression stroke), not #1. since the rotor is keyed to only go in one way, you'll need to pull up enough on the distributor and re-index. basically, you're just out 180.
After your experimentation it's very likely you'll need to start fresh with a confirmation of TDC at #1 using a TDC tool which you can likely get as a free/rental at your local AP store. You might search for an explanation of how to and then also confirm the spark plug wire routing arrangement that you've got in the distributor cap.
Do you have a FSM?
Do you have any sort of motor manual that you used OR ...........
Actually some might suggest either, or a combination.
The image I posted should explain the 180, you apparently aligned the dimples "facing one another" which is #6 and for #1 TDC cam dimple needs to be at 12:00 and the crank dimple at 12:00 also. It's something that's done frequently by many.
http://www.crankshaftcoalition.com/w...ng_valve_cover
Don't let the read confuse you and the drop of the distributor is I believe pretty accurate when they mention 5:30. The read can't be considered gospel but it's very good "familiarization".
Now for my other timing problem... I set my timing with the light, brown wire disconnected, turned it off reconnected the wire, and pulled the negative off my battery. I let it sit for 5 mins or so then reconnected the battery, fired it up and my timing is showing way advanced, like above my timing marks by an inch or more. What gives? The computer advancing it for some reason? It also causes it the idle at 1100 rpm, which is what it was doing before when i decided to replaced my timing chain and gears. Happy its runing again but replacing all that didnt help my original issue. Can you guys help me out again?
Start and run engine until it reaches operating temperature (closed loop)
Check and set ignition timing to 6 degrees before dead center (BDC) with tan EST wire disconnected
Check and set throttle position sensor (TPS) to .54 (+/- .08) volts at idle
Jumper terminals "A" and "B" on the ALDL
Turn ignition key on and do not start engine
Wait 60 seconds so that the idle air control (IAC) motor fully extends
Without turning ignition key off, remove connector from IAC motor
Turn ignition key off and disconnect ALDL jumper
Attach external RPM meter using Tach port or scanner using ALDL port
Remove minimum idle air cap using awl if required
Adjust idle speed to 425 (+/- 25) rpm in either in park or neutral
Turn ignition key off and reconnect EST wire and IAC motor
Reset ECM by disconnecting and reconnecting power at battery terminal
Depress accelerator pedal slightly
Start and run engine for 5 seconds
Turn ignition key off for 10 seconds
Drive vehicle to assist in ECM reprogramming
If you used a scanner, you should see around 20 IAC steps -
