4 letter prom code on my chip?????
Old Aug 21, 2002 | 05:41 PM
guywade's Avatar
guywade
Default 4 letter prom code on my chip?????
where would i find that ? now be nice :D how would i get to it, if i need to remove anything i need instructions as i have zero knowledge working on electronic cars, used to the old stuff. :cool: :cheers:
Old Aug 21, 2002 | 05:56 PM
scorp508's Avatar
scorp508
In the engine compartment is your ECM over above the battery. Unscrew that, flip it over and take off the cover hiding the memcal. Unclip the memcal and look through the window on the plastic (probably blue) cover. There should be a little white/silver tag on the EPROM that has it.
Mine says ABTB 0135 on it.
Old Aug 21, 2002 | 05:59 PM
ZylaRace's Avatar
ZylaRace
Default Re: 4 letter prom code on my chip????? (guywade)
I'll presume youhave an early C4. So you prlbably have a 165 ECM.
You are looking for the small panel that covers the CalPack in the ECM.
i.e. Find you ECM. Easiest to remove form the car. Unscrew the two screw that hold on the small ~2"x4" cover in the middle of the case. Vowla,... that blue thing is your CalPack. Look thru the little round/oval opening in the blue cover. There will be your BCC code. If you flip the 2 levers at the top and bottom of the CalPAck, it will pop out. In this state all is relativly safe. If you decide to pop the blue cover off, (it is best not to) beware of ESD (static). The original PROM is soldered in. Don't try and pop it out.
Old Aug 21, 2002 | 06:17 PM
guywade's Avatar
guywade
Default Re: 4 letter prom code on my chip????? (ZylaRace)
if the prom is soldered in, how would i replace it when the time comes? i hope this ain't one of those should take 5 minutes but since yours is soldered now the job takes 2 hours! TIA Bro
Old Aug 22, 2002 | 12:24 AM
2012 coupe's Avatar
2012 coupe
The four letter code is also printed on the sticker on top of the ECM, well at least my 1992 is that way.
:flag
Old Aug 22, 2002 | 09:07 AM
Rich B.'s Avatar
Rich B.
You don't. You could...And many have...But due to popular demand, one of the denizens of 3rd Gen has produced an adapter that plugs into your ECM and allows you to put *both* your MemCal and a new EEPROM into it. The ECM will read the new BIN off the EEPROM, while still retaining the ability to read the "limp-home" chip(s) off the MemCal.
Check the stickies at the top - look for Craig Moates - http://www.thirdgen.org/techbb/forum...ne=&forumid=16
Old Aug 22, 2002 | 11:04 AM
ZylaRace's Avatar
ZylaRace
Default Re: 4 letter prom code on my chip????? (Rich B.)
A 90 Vette should have a 727 ECM. (First of the SpeedDensity cars.) 256K PROM. That ~12"x10" metal finned thing mounted above your battery, is your ECM.
The Moates adapter seems popular. I have not used it.
[Modified by ZylaRace, 9:56 AM 8/22/2002]
Old Aug 22, 2002 | 12:27 PM
Rich B.'s Avatar
Rich B.
I have two. They fit both 165 and 727 (or F-body 730). Very handy to have. Easy to use.
And they are reasonable... :yesnod:
To 4 letter prom code on my chip?????
