89 wheel cap locks
Old Aug 20, 2015 | 05:20 PM
C-4 owner's Avatar
C-4 owner
Default 89 wheel cap locks
my key is wore out # 13049 is there any way to get a new one?Is there any other way to get these out?
Old Aug 21, 2015 | 07:46 AM
shootnstarz's Avatar
shootnstarz
How many different patterns are there?
Rick
Old Aug 22, 2015 | 07:41 AM
shootnstarz
Since nobody else has an idea if you can't get them off any other way there's always drilling the head off or my preferred way would be to have somebody carefully tack weld a small bolt to the head and back it out that way.
Or maybe grove the head with a Dremel abrasive wheel and try using a screwdriver. Whatever method you use it's not going to be a picnic.
Rick
Old Aug 24, 2015 | 01:50 AM
eguyett1985's Avatar
eguyett1985
Try calling McGard, I believe they supplied them to GM originally.
Old Aug 24, 2015 | 08:55 AM
WVZR-1's Avatar
WVZR-1
I do believe that McGard was the vendor and in the past with information a key was generally available. I've actually sent them a digital image of locks in the past and they've ID'd the key and replaced them. Of course for a fee.
Do they still or will they? A phone call will answer that. I'd avoid e-mail contact and tolerate a phone system if I actually needed something.
http://www.mcgard.com/index.php/cust...nt-information
I had some wheels with a similar retention system/lock and once I ID'd the thread I used some Torx head pan-head screws to replace them. I wasn't concerned with security and/or appearance at the time and these weren't for a Corvette. I believe you could do the same with either chrome or stainless if you weren't concerned with the security. ID the thread and give it a go.
Old Aug 24, 2015 | 11:11 AM
Churchkey's Avatar
Churchkey
Do not recall the inside depth of the wheel lock key, sold the 89 15+ years ago.
What works for me on worn wrench sockets is to dress down the working end on a belt sander effectively removing the worn edge & restoring the tool definition.
Old Aug 24, 2015 | 06:06 PM
shootnstarz
Sure sounds like a better plan than mine !!!!!
Rick
To 89 wheel cap locks
