Idle/Stall/Valve Lash issues
Bought my 85 Coupe last January for next to nothing- with a spun rod bearing. Rebuilt bottom end of the motor (turned crank, new bearings) but in the diagnoses of the bearing, I checked the top end too, looking for bent pushrods and such. Obviously I had to significantly alter my valve lash in order to do this and now, after resetting it (I thought) the valvtrain is excessively loud and the car is stalling at idle. It'll run for maybe 80 seconds before it dies.
I took the throttle body off, cleaned it and the IACV, and (because it was there) bypassed the throttle coolant. Once I reinstalled the TB, the issue seemed to be worse and I can't seem to find the issue. No vaccum leak as far as I can tell.
Could the issue be the valve lash? I know I'll need to correct that regardless. But I'm not sure if that's the cause of the problem or a separate issue. Thanks!
In any case, there are a million threads and videos around on how to adjust the valves on a SBC. I prefer the warmed up and running, but messy method. I'd fix that before I worried about anything else. Misadjusted valves can make it run badly for sure.
I'm going to readjust the valve lash and see if that helps the car run more smoothly. Oil pressure is fine as only the drivers side cylender bank is noisy (the only one i messed with inthe first place) and I'm reading good pressure.
If it is a new flat tappet cam or even just new lifters did you follow break in procedure? Even if it's just new pushrods and rockers I break them in like a cam kinda.
Initially I thought the issue with the motor was top end (sounded like a bent pushrod) so I pulled the valve cover on the drivers side cylender bank and checked all the pushrods for any kind of damage, cleaned them, and then returned them to their positions. I then attempted to reset valve lash but it doesn't look like I did it correctly and now I'm stalling out.
try a re-adjustment across the board, turning the nut until you FIRST feel resistance, and adjust your 1/2 turn.
BTW, you don't need to get TDC for each cylinder, here's pretty much the factory method -
Get #1 to Top Dead Center - adjust
Exh.- 1 – 3 – 4 - 8
Int.- 1- 2 – 5 - 7
Get #6 to Top Dead Center - adjust
Exh.- 2 – 5 – 6 – 7
Int.- 3 – 4- 6 - 8
Adjust until you first feel resistance on the pushrod spin and then add either 1/2 or 3/4 turn.
BTW, I personally use a .0015 feeler gauge to find zero lash. with the feeler gauge between the rocker arm and the valve stem, adjust the nut until you first feel the gauge grab - and no further. at that point, you should be within .001 of zero lash. now adjust 3/4 turn.
hope this helps -
