89 starting issue HELP
Old Aug 23, 2015 | 03:19 PM
KingBiscuit2112's Avatar
KingBiscuit2112
Default 89 starting issue HELP
I added the "HELP" because my wife leaves on business in 2 days. Friday my car had trouble, the starter was only clicking like it would if you had a dead battery. I show11.7 volts and fans and lights work well. After I would try it 8-10 times it would work just fine. Stater (with cylnd) installed a month and a half back. A few time it's run when I turn the key but no hooked up gear wise good and would just spin. I'm limited on what I can do.... never was very good and a bad ticker now.
Please, can anyone give me some quick help?
Old Aug 23, 2015 | 04:02 PM
antfarmer2's Avatar
antfarmer2
Make sure the connections are tight and clean. Might just have gotten a bad battery.
Old Aug 23, 2015 | 06:02 PM
KingBiscuit2112
Checked, seems tightly connected. I noticed that one of the many times I tried to crank it my miles per gallon, distance to empty dropped to 1.8 to 35 miles to empty. Just filled up.
Old Aug 23, 2015 | 06:25 PM
antfarmer2's Avatar
antfarmer2
To low on volts battery or alt
Old Aug 23, 2015 | 06:46 PM
KingBiscuit2112
seems to have plenty of juice but i'm charging the battery anyway.
Old Aug 23, 2015 | 09:29 PM
KingBiscuit2112
And of course that didn't work. About to get something more reliable like a used Yugo or something. Pretty much pissed off.......
Old Aug 24, 2015 | 04:18 AM
kenmohr's Avatar
kenmohr
You have a bad battery. Should read more than 11.7 volts. Have it checked.
Old Aug 24, 2015 | 08:40 AM
KingBiscuit2112
Charged it. Still nothing... 12 volt battery, it's always read about that. Did this Friday off and on.
Old Aug 24, 2015 | 08:52 AM
antfarmer2's Avatar
antfarmer2
A yugo still needs a battery. Don't blame the car.
Old Aug 24, 2015 | 11:04 AM
KingBiscuit2112
You seriously think it's the battery? 11.7 or so is what it's always read. I'll have to look and see how to even get the battery out...Interior lights and a/c fan seem at full strength.
Old Aug 24, 2015 | 08:50 PM
Cliff Harris's Avatar
Cliff Harris
Check the negative battery cable connection on the side of the block above the oil filter.
Check the positive battery connection on the starter solenoid. Since work was done in this area it's a prime suspect.
Old Aug 24, 2015 | 09:12 PM
KingBiscuit2112
Just bought a battery I'm changing in the morning (pain in the butt) Old one appears to be 5 years old. Needs one anyway. No Jack stands and a bad ticker...limited on my ability. Wish I'd tried this kinda stuff when I was young. Of course no Vette when I was young either.
Old Aug 24, 2015 | 09:25 PM
WVZR-1's Avatar
WVZR-1
Battery replacement is very straight forward and simple. DO NOT MAKE IT more complicated than it needs to be.
Here's a couple videos. I've never watched the second one. The second one might make most of us smile a little. I watched the first minute or so and I added it "just because". Disregard his tool suggestions and just use the "right stuff".
Old Aug 24, 2015 | 09:28 PM
antfarmer2's Avatar
antfarmer2
Don't set it on the ground
Old Aug 25, 2015 | 08:39 PM
KingBiscuit2112
Default This SUX. No the battery
Well I spent 1 1/2 hours changing the battery an NOTHING!New battery is reading 11.9 but at this point who knows, electronic may be screwed too. Took soooooo long because some idiot put a bolt that holds the battery down that had a square head. Nothing fit it, had to inch it along with about 3 different tools. No floor jack or stands so noway to get underneath and look further. I guess I'll ride my 4 wheeler to work and hope the doughnut shops are full.
Old Aug 25, 2015 | 08:49 PM
antfarmer2's Avatar
antfarmer2
Going to have to get it on a lift.
Were you going by the car or a meter for the volts?
Old Aug 25, 2015 | 09:00 PM
KingBiscuit2112
Car...
To 89 starting issue HELP
Old Aug 26, 2015 | 06:45 AM
kenmohr's Avatar
kenmohr
Car...
Take the car to autozone or other and have them check the bat and system properly.
Old Aug 26, 2015 | 06:11 PM
KingBiscuit2112
Battery change and still 11.7. Had it towed in this morning and it was the security system, kind of. still have to use a key with a chip but between the ignition and the next spot that wire hooks up it wasn't getting juice. Weird though, security system usually kills everything, this time electronics were turning on under the hood... I could here a/c compressor and a few other things make noise. BUT now I have 13.2 volts.
Old Aug 27, 2015 | 12:02 AM
Cliff Harris
VATS disables the starter and prevents the ECM for firing the injectors. It does not affect anything else.
