Noob question. Crack or normal?
Old Aug 24, 2015 | 10:58 AM
bls72bmw's Avatar
bls72bmw
Default Noob question. Crack or normal?
Outside right now doing plugs rotor wires etc.
Is this crack normal? On the same place both sides.
Old Aug 24, 2015 | 11:39 AM
John A. Marker's Avatar
John A. Marker
Since it is on both sides of the part in exactly the same spot. I would say it is normal. Is this a solid piece of metal...or multiple layers? It also looks like the two parts have been spot welded.
Old Aug 24, 2015 | 01:17 PM
ToniJ1960's Avatar
ToniJ1960
I think its norml if that's a coil its just the laminations
Old Aug 24, 2015 | 01:29 PM
bls72bmw's Avatar
bls72bmw
Thanks, was outside in the middle of replacing some parts in a tune up and just wanted to be sure before putting it all back together.
It's the coil sides that look like 'layers' on top of one another.
Much appreciated, runs great!
Old Aug 24, 2015 | 08:57 PM
WVZR-1's Avatar
WVZR-1
I ain't real sure but aren't there primary and secondary windings in an ignition coil and maybe just maybe the halves are differently polarized? It seems like the only rational assumption but I certainly ain't sure.
I'm sure all HEI coil 'n cap coils are constructed similarly.
Old Aug 24, 2015 | 09:22 PM
jv9999's Avatar
jv9999
It's fine. It's made in two pieces so the one piece coil windings can go in the middle.
Old Aug 25, 2015 | 07:15 AM
shootnstarz's Avatar
shootnstarz
And clean that disgusting rust off before you reassemble :-)
Rick
To Noob question. Crack or normal?
