Rear end fluid change time
Old Aug 21, 2002 | 09:29 PM
69mako's Avatar
69mako
Default Rear end fluid change time
It's time to pull the old rear end fluid out of the blue monster(94 LT-1 coupe) :yesnod: I have a small bilge pump that I used to do the same thing on my 72 :cheers: worked great at sucking out the all the old fluid :yesnod:
My question is: what size allen wrench is needed to remove the bolt plug on my 94's rear? I have Mobil 1 gear oil and anti slip waiting to go in.
Thanks, Larry :cool:
Old Aug 21, 2002 | 09:48 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Rear end fluid change time (69mako)
I think it's about a 3/8" allen wrench.
Old Aug 22, 2002 | 01:10 AM
TA's Avatar
TA
Default Re: Rear end fluid change time (Bob86ZZ4)
You are correct, sir :yesnod:
To Rear end fluid change time
