Burnt a program now hunts for idle
Old Aug 25, 2015 | 10:44 AM
Billygoatkid's Avatar
Billygoatkid
Default Burnt a program now hunts for idle
Hi,
So I used a modified abtp bin and noticed after it warmed up the idle was hunting to point where car just stalls. I them loaded a stock abtp bin and it does the same thing. Is it possible after I reset and disconnect the battery that the ecu needs to learn once in closed loop? I disconnect the battery after loading in a new bin. Thx
Old Aug 25, 2015 | 05:25 PM
DanielRicany's Avatar
DanielRicany
Try setting the timing to 20.04 degrees at all areas of 400, 800, and 1000 RPMs in the tune. Set initial to 6 degrees in the tune, and make sure your distributor is at 6 degrees base timing.
Old Aug 25, 2015 | 05:39 PM
Billygoatkid
Ok thx I'll try that. Yes my base timing is set at 6'.
Old Aug 31, 2015 | 10:35 AM
Billygoatkid
So it was my O2 sensor which the wire had melted against the exhaust.
That issue fixed yay
Old Nov 18, 2015 | 01:03 PM
THE 383 admiral's Avatar
THE 383 admiral
perfect advice. 20 Deg 800 & below. 1000 should start at 32 up to 36 then taper back down to 20 Deg at WOT.
Also update your target Idle RPM. GM Loved to stagger this idle per temp. Match your RPM lets say from 32 deg C Through 116 deg C @ 650 OR 700 your Preference.
To Burnt a program now hunts for idle
