Speedo Gear
Old Aug 22, 2002 | 07:34 AM
keekster's Avatar
keekster
Default Speedo Gear
I went from the stock 2:59's to the stock 3:07. When I change my Speedo sensor and gear do I have to do the driven gear on the tail shaft also ?
[Modified by keekster, 11:35 AM 8/22/2002]
Old Aug 22, 2002 | 10:56 AM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Default Re: Speedo Gear (keekster)
I read in your profile that you car is an 89, for 93 and previous you must change out the gear on the tail shaft, only the 94-96 can be done with the programmer. I got me gears from Doug Rippie. They were a pain to get on because the new gear for the tail shaft is metal(original is plastic and just slides on).
I have a 6spd but I believe it is the same deal for the auto,, good luck
Old Aug 22, 2002 | 08:12 PM
Jay Axson's Avatar
Jay Axson
Check out the "New Gears" thread. In it is a link to a pictorial of the speedo gear swap. It looked pretty easy.
*edit* Here is the page http://forums.corvetteforum.com/zerothread?id=288585
[Modified by Jay Axson, 6:13 PM 8/22/2002]
Old Aug 23, 2002 | 01:28 PM
dgoodhue's Avatar
dgoodhue
You will need
A new VSS (gm #25007308) and a driven gear (gm #25513049)
Fortunately you do not need to swap the drive gear, which require the remove tail housing of the tranny.
Old Aug 23, 2002 | 03:19 PM
keekster's Avatar
keekster
Default Re: Speedo Gear (dgoodhue)
THANK YOU !!!!!
That is what i was hoping :)
To Speedo Gear
