92 A/C Clutch Coil
Has anybody had to resolve this issue?
How did you get around the missing hole.
It can't be drilled it out, the spot were it looks like the hole in the plate might go is over the coil.
I ordered a A/C clutch assembly.
After removing the old coil, started the reassembly and found the Coil plate on my original part that mates to the compressor has an additional hole for a locating pin on the compressor face.
In the Picture the new coil is on the left and original is on the right.
Thanks all,
Roy
Will see if they can resolve the problem.
Just seeing what option I have if they don't have the correct coil.
Thanks,
Roy
