Is It Difficult to change Flywheel Ring Gear ?
Old Aug 22, 2002 | 12:43 PM
CAJUN C4's Avatar
CAJUN C4
Default Is It Difficult to change Flywheel Ring Gear ?
Have a Bad spot on my Flywheel I think..Every once in a while it Grinds the Starter to Flywheel. Anyone change just the Ring Gear ? Procedure ?
Old Aug 22, 2002 | 12:49 PM
JonM's Avatar
JonM
Default Re: Is It Difficult to change Flywheel Ring Gear ? (CAJUN C4)
Sounds more like the starter is not engaging all the way, all the time
Old Aug 22, 2002 | 12:52 PM
CAJUN C4's Avatar
CAJUN C4
Default Re: Is It Difficult to change Flywheel Ring Gear ? (JonM)
Yes, Doesn't do it all the time..I put a Starter Shim in it last year helped I think. With 200K mi. must be getting worn...I might try another shim?
Old Aug 22, 2002 | 01:00 PM
JonM's Avatar
JonM
Sure try another shim, but if I were you I would carry my cell phone and the number of your local tow company. :yesnod: Take the damn thing out and have it tested. Free at AZ or Advanced
To Is It Difficult to change Flywheel Ring Gear ?
