what are the stock rr's on a 90 vert 5.7 , what would be the next best to put on without having to change valve covers?? is this worth doing on a l98 that has poor breathing heads ??? or is there something else i could do that would make horse power, i know i still haven't got the headers yet, TIA
Switching over to full roller rockers is pretty easy and going with a higher ratio also should give a moderate gain. People have had problems with 1.6 ratios contacting drip tabs, so you may have to grind these off. Also full rollers tend to be wider than stamped rockers so you will need to make sure they fit with the centerbolt configuration.
