Camshaft options
Old Sep 5, 2015 | 03:21 PM
Mohammed_z's Avatar
Mohammed_z
Default Camshaft options
Does anyone know few Camshafts that are better than hot cam ?
I mean for power gains and better drivability.
for LT1.
Old Sep 5, 2015 | 05:51 PM
96 lt-4's Avatar
96 lt-4
http://www.advancedinduction.com/LTX...Valvetrain.php
Ai 220 / 230 - .560" / .555" - 112 LSA
Our version of a GM LT4 Hot Cam, but with the potential to make another few hp over the old GM grind. Typically makes peak power at 5800-6000rpm in stock LT1 long blocks. Properly tuned this small grind will run and drive well with stock gearing & converter.
Ai 226 / 234 - .566" / .566" - 110 LSA
Easily our most popular daily drivable grind for 350cid applications. Typically makes peak power at 6000-6200rpm in stock LT1 long blocks. Properly tuned it will run and drive well in M6 cars w/ stock gearing. A4 cars should run a 3.42+ rear end gear & 2400 rpm converter minimum. Can pass emissions in some states on 110° LSA, though 112-114° LSA makes it more likely to pass.
Either one of these would do well.The first one would be a better choice most of the time unless you have done other modifications.Make sure you change the valve springs and it would be a good time for a roller rocker upgrade.You will need to have the computer tuned as well.I am sure you already know this but posted it just in case you don't.
Old Sep 6, 2015 | 12:17 AM
Mohammed_z's Avatar
Mohammed_z
Nice
my car has the hot cam package with springs and higher rocker ratio, the power range is good. But i'm not comfortable with the idle. I wish it was little smoother.
Will check those, thanks
Old Sep 6, 2015 | 12:27 AM
cv67's Avatar
cv67
St. Jude Donor '05
How much time was spent tuning it, not sure a cam change (esp larger) is the answer
Old Sep 6, 2015 | 02:46 AM
Mohammed_z's Avatar
Mohammed_z
It was installed and tuned before I buy it.
Do you mean the tune was not good enough ?
Old Sep 6, 2015 | 03:31 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Are you sure it is a Hot Cam?
The Hot Cam is a very very mild cam, with almost a stock like idle, and a very small lope.
Old Sep 6, 2015 | 06:10 AM
Mohammed_z's Avatar
Mohammed_z
Thats what ive been told by previous owner. I will record a video and post it here.
How can it be almost stock idle while it is 112 LSA ?
Old Sep 6, 2015 | 07:29 AM
96 lt-4's Avatar
96 lt-4
The wider the LSA the more tame the idle is.Hot cam has a little lope at idle but is not radical by any means.
Old Sep 7, 2015 | 07:46 PM
silvvette's Avatar
silvvette
Am doing the same. I had the hotcakes on another build (imp ss lt1) ND am going with the cc503 or gm846; both are about the same spec and higher yield over hotcam.
To Camshaft options
