throttlebody
Old Aug 22, 2002 | 05:49 PM
mak567's Avatar
mak567
Default throttlebody
does anyone know how to remove the throttle shaft off of an l98 tb.
Old Aug 22, 2002 | 11:09 PM
Les 94 Comp Yellow's Avatar
Les 94 Comp Yellow
Default Re: throttlebody (mak567)
If it's the same as an LT1 you remove the butterfly plate on each side and slide the shaft out towards the linkage control side of the body. Hope this helps, Les
