Need Help!!! (1984 C4 Corvette)
Old Sep 10, 2015 | 08:59 PM
Brxndon's Avatar
Brxndon
Default Need Help!!! (1984 C4 Corvette)
Hello my guys I recently got my grandfathers 1984 Corvette and I need help. I'm currently 17 and trying to fix up the car. I've been a car kid all my life. I go to school and work hard to keep the car up in good standards. Some issues I'm having is that the Battery is being drained. I can jump start the car perfectly and it will run but 10-15 min later the battery will drain. In addition, I think it might have to do with my grandfather who installed a after market radio in it but I took it out already. Please help me guys I really need this problem fixed. Is there a temporary fix i can do until i take it in to get checked out? Also does anybody know what the shell of the car is made out of? I feel as if it's fiber glass but i might mot be sure. Thanks again.
Old Sep 10, 2015 | 09:30 PM
jv9999's Avatar
jv9999
Are you sure the battery isn't just tired? The symptoms would be the same. Have a parts store test it.
It's a Corvette, of course it's fiberglass :-)
Old Sep 10, 2015 | 09:32 PM
Brxndon's Avatar
Brxndon
What exactly do you mean by tired ?
Old Sep 10, 2015 | 09:35 PM
xrav22's Avatar
xrav22
Could be a bad alternator, are the battery cables tight and in good condition, also when it is running switch the guage to alt or volts and it should read 13.5-14 volts.
Good luck
Old Sep 10, 2015 | 09:36 PM
Brxndon's Avatar
Brxndon
Good luck
It reads around 12.4 Volts but once i start driving it goes to 13.4
Old Sep 10, 2015 | 09:48 PM
xrav22's Avatar
xrav22
That should work, like the OP said an old battery won't hold a charge.
Old Sep 11, 2015 | 12:51 AM
The Thomas J's Avatar
The Thomas J
Battery and or alternator. From what I understand replacing a C4 battery isn't as straight forward as it appears. Be sure to read one of the tutorial reviews before you attempt to remove it yourself. Good luck OP. A corvette of any era is a great first car...even if it is a crossfire.
Old Sep 11, 2015 | 01:46 AM
odxr's Avatar
odxr
Most young people are not into cars these days.I wish you much luck learning about the car.2 hints for you-remove the battery cables and clean them.Side terminal batteries can hide corrosion.If your car has the Bose sound system the rear speakers have little amplifiers attached to them and there is a relay that powers them.The relay contacts stick and keeps 12v on the amps when the car is shut off.Its behind the carpet by the hatch latch.I would suggest going to a website called Alldata and getting a 1 year subscription for your car.Its the original GM factory service manual for your car online and you can print pages from it.If you drive the car in bad weather make sure you have good tires on it.1984's had stiff springs and the rear of the car slides easy.
Old Sep 11, 2015 | 05:26 AM
Brxndon's Avatar
Brxndon
Thanks man will do. I feel as if it's a combination of things but I will see if it's just the the battery can't keep a charge.
Old Sep 11, 2015 | 05:28 AM
Brxndon's Avatar
Brxndon
I get exactly what your saying. I feel like my generation is not into classics like it should be. I learned the value of things at a young age when my family could not afford things but For sure i have to check that constant line running to the speaker.
Old Sep 11, 2015 | 07:35 AM
Black LS2's Avatar
Black LS2
Pull the battery and take it to Wallyworld...they have great testers...and do it for free.
Old Sep 11, 2015 | 09:47 AM
playsdixie's Avatar
playsdixie
welcome to the forum...lots of good advice here....sounds like you need a new battery but it's possibly a big battery drain...get your battery tested and replaced if needed....disconnect the positive cable and put a meter between the post and cable to see if there is any drain....my battery just went low due to leaving the key on, alternator amps are over 14 until it charges fully....keep posting your efforts, you'll get lots of assistance.
Old Sep 11, 2015 | 01:26 PM
JCrock's Avatar
JCrock
What you're looking to have done is a load test on the battery. Pretty much any auto parts store and Walmart too can do it. You need to make sure you have a good battery before troubleshooting things.
I must be getting old, I just can bring myself to think of a 1984 as a classic.
Old Sep 11, 2015 | 01:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
w/everyone who thinks you should start by testing the battery.
Or do your own load test. Charge up the battery by whatever means you like (charger, running the car, jumpers...whatever). Remove the charge, install a DVOM to monitor voltage. Volts should be in the 12v range. Turn on your headlights on high beams, heater blower on high, then watch voltage...it will drop some at first, but should stabilize at maybe ~11.5v or so?
My guess is that w/your battery, the volts will plummet. The battery will be proven to be bad.
Old Sep 11, 2015 | 02:17 PM
whalepirot's Avatar
whalepirot
I like a DVM plug-in tool to see the system voltage and use it in my cars to realtime monitor voltage readings, this esp with the "inaccurate" C4 dash readings. It was a savior in a 745 BMW, too (POS German engr)
The body is SMC, or Sheet Molded Compound, a polyester resin based, fiberglass composite.
Old Sep 11, 2015 | 04:42 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
I was hoping someone would post that before I got to the last post or I would have. Brxndon, if you do any body work on your new toy you should research SMC repair. Good luck with your corvette.
Old Sep 11, 2015 | 09:01 PM
Brxndon's Avatar
Brxndon
Yea I jumped the car this morning and then turned it off. after that I tryed to jump it again but it just couldn't hold a charge so i think it is that the battery is bad.
To Need Help!!! (1984 C4 Corvette)
Old Sep 11, 2015 | 09:05 PM
Brxndon's Avatar
Brxndon
Yea I'm just trying to make the car good enough to be a daily driver. I don't drive the car to hard so I'm trying to preserve the body and parts as much as possible until i have enough money to fix the stress cracks in the body. But thanks for the help man.
Old Sep 12, 2015 | 08:17 AM
Brxndon's Avatar
Brxndon
How can I remove the glue adhesive left on the car from the removal of the corvette badge in the rear without stripping the paint.
Old Sep 12, 2015 | 09:10 AM
antfarmer2's Avatar
antfarmer2
wd40 or goo-gone
