help
Old Sep 13, 2015 | 06:36 PM
catbatrat01's Avatar
catbatrat01
Default help
I have a 1985 corvette and I replace the fuel pressure reg and now the fuel is going up and down
Old Sep 13, 2015 | 06:49 PM
antfarmer2's Avatar
antfarmer2
you mean the fuel pressure is going up and down? What are the numbers? Did you replace the filter?
bad vacumme line bad pump cloged pump sock leaking hose from pump need more info
Old Sep 13, 2015 | 07:28 PM
catbatrat01
key on engine off, fuel pressure starts at 45, then drops within 5 seconds to 10 psi.
cleaned gas tank
cleaned sending unit
new fuel Pressure Regulator 9-11-15
new Intake Gasket 9-11-15
new tune up 8-31-15
new fuel filter 8-15-15
new pick up coil for distributor 9-1-15
new iavc 9-3-15
new throttle body gasket 9-3-15
new the maf sensor9-3-15
brand new radiator 9-4-15
new thermostat and gasket 9-4-15
new relay for cooling fan 9-4-15
new fuel pump 9-13-15
Old Sep 13, 2015 | 07:33 PM
antfarmer2's Avatar
antfarmer2
take a look at the hose in the tank from the pump sounds loose or you got a bad pump.
did this just start doing this?
could be bad injectors too
any fuel in the oil?
Old Sep 13, 2015 | 08:17 PM
catbatrat01
when I installed the new fuel Pressure Regulator Saturday the problem started .key on engine off, fuel pressure starts at 45, then drops within 5 seconds to 10 psi. when I had the old fuel Pressure Regulator key on engine off, fuel pressure starts at 45, then when I stared engine 40psi to 42psi
Old Sep 13, 2015 | 08:24 PM
antfarmer2's Avatar
antfarmer2
might have a bad new fpr I would put the old one back in and smell for fuel in the vacumme line and oil.
Old Sep 13, 2015 | 08:49 PM
catbatrat01
the old fuel Pressure Regulator when I started the engine I smell gas
Old Sep 13, 2015 | 09:05 PM
antfarmer2's Avatar
antfarmer2
might be injectors stuck open.
it was running before you put the new fpr on I would put it back on and do some testing new parts can be bad
Old Sep 13, 2015 | 09:34 PM
catbatrat01
The reason I pUT all the new things on my Corvette was from the beginning when I started it it would stay on for a little bit turn off and eventually would stay on after few minutes but then when I went someplace I turned it off it wouldn't start up again was hard to do after eight or nine times it would stay on
Old Sep 13, 2015 | 09:59 PM
antfarmer2's Avatar
antfarmer2
so once you got it running it ran good? when and where do you smell fuel? out the exaust the oil or the vacumme line? before you changed the fpr how long would it hold pressure? does the oil smell like gas now? how many miles on it and are the injectors original?
Old Sep 13, 2015 | 10:29 PM
cohocarl's Avatar
cohocarl
The way I understand it, the fuel pump relay turns on your fuel pump for a couple seconds when you turn on the key. Will it start and then keep pressure? Once you start the engine and build oil pressure, it keeps the fuel pump lit. It may be operating correctly.(?)
Make sure you didn't nick one of the many o-rings on the fuel rail and it's leaking.
Old Sep 13, 2015 | 11:06 PM
catbatrat01
yes it ran good until I turned it off and tried to restart it took 8 tries im not sure where the smell is coming from. once started it held pressure 40-42 psi 73,000miles
injectors are original no the oil doesn't smell like gas
Old Sep 14, 2015 | 07:36 AM
blackozvet's Avatar
blackozvet
what sort of regulator did you put in, what brand ?
if it holds pressure while its running then i wouldnt stress too much.
the standard regulators were designed to hold pressure due to EPA regulations governing evaporation of fuel from fuel systems.
I have run aftermarket regs in my TPI and single plane intakes that drop to zero almost instantly the engine is shut off, but they dont affect the way engine runs.
Old Sep 14, 2015 | 09:29 AM
playsdixie's Avatar
playsdixie
you have two threads with the same issue....sounds like either the check valve is bad in your pump or the lines just above the pump are loose or cracked....if you had to clean the tank and the sender, probably would have been a good time to change the pump, considering you threw so many parts at it anyway...
Old Sep 14, 2015 | 09:40 AM
catbatrat01
wells prd7
Old Sep 14, 2015 | 11:16 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
wells prd7
Going to venture to say that if u inspect the fpr hoses, you might find cracked or damaged from the swap. if not, get another fpr as the new one clearly isn't working as well as the previous one.
then if your injectors are originals, i'll venture they need to be replaced. i am actually surprised Aklim hasn't said that yet. what is the name of the guy everyboy uses here?
and finally, as others have said, check the hoses at the fuel pump.
also, try the pedal to the floor trick to clear the injectors and see if it starts. at least this will tell you if your injectors are flooded??
Old Sep 14, 2015 | 07:18 PM
blackozvet's Avatar
blackozvet
wells prd7
thats a standard type diaphragm replacement so it should hold poundage after shut down, did you use your original housing ?
To help
Old Sep 14, 2015 | 07:24 PM
antfarmer2's Avatar
antfarmer2
I am still betting his new fpr blew the pulsator or rubber line off his fuel pump with a leaky injector (s)
Old Sep 14, 2015 | 07:51 PM
Den14's Avatar
Den14
Jon At Fuel Injector Connection can help you. Ohm them all out first to se if any are different than the others.
Old Sep 14, 2015 | 07:57 PM
VikingTrad3r
Oil Producer
but as Aklim says all the time, that doesn't tell you if they are stuck partially open or closed does it?
