Stuck engine update
Old Sep 15, 2015 | 07:06 AM
jseremba's Avatar
jseremba
Default Stuck engine update
First let me apologize for starting a new thread about this. But, I put Stuck in the search bar and could not find the old thread.
So I had the engine soaking in ATF, crankcase, and marvel in the cylinders. I took two turns off the rocker arms and I made an engine turning tool. A flat piece of steel with a bolt welded to the middle. I then fastened that to the damper pulley. And with a few back and forth turns of the torque wrench the motor rotated freely.
So now put on the water pump, change the thermostat and fire it up.
One question will it fire up without me putting on the water pump and the EGR. I would just like to see if it will run. Then I would like to do a compression test. Before I reassemble the parts and find out I have to take it apart anyway.
Thank you for all your advice. It was ia big help.
Old Sep 15, 2015 | 09:19 AM
antfarmer2's Avatar
antfarmer2
I would do the compession test first after ajusting the valves
Old Sep 15, 2015 | 10:10 AM
jseremba's Avatar
jseremba
If I do the compression test now. It will be a wet test. I would rather run the car. Get all the marvel out of the cylinders. Then I can do a dry and wet test.
Will the car start and run without the egr connected?
Thank you
Old Sep 15, 2015 | 11:03 AM
tbirdsps's Avatar
tbirdsps
The car will not run if the EGR is not installed. Huge vacuum leak. It doesn't have to function, just be installed or a blank off plate in it's place.
Old Sep 15, 2015 | 11:09 AM
jseremba's Avatar
jseremba
My bad I mean the air pump up front, sorry.
Old Sep 15, 2015 | 11:38 AM
antfarmer2's Avatar
antfarmer2
the air pump will be ok don't run with the valves loose might bend something
Old Sep 15, 2015 | 12:06 PM
jseremba's Avatar
jseremba
Thank you. The valves are back to the position I loosened them from.
I was afraid the computer would not let the car run
To Stuck engine update
