headlight issues
Old Sep 15, 2015 | 04:58 PM
rgbrown's Avatar
rgbrown
3rd Gear
Default headlight issues
every time i turn on my head lights in my 93 my dash lights go out????
Old Sep 15, 2015 | 07:30 PM
antfarmer2's Avatar
antfarmer2
I would check the fuse box connection where the hot wire comes from by the battery.
Old Sep 16, 2015 | 12:02 AM
Cliff Harris's Avatar
Cliff Harris
Sounds like a bad photocell in the dash.
The dash lights are much dimmer at night and when you turn on the headlights the dash thinks it's night and puts the back lights into dim mode. The photocell is supposed to over ride this and make the back lights bright because they must be bright to be seen in daylight. This appears to not be happening in your case.
To headlight issues
