Rear diff proper level
Old Sep 18, 2015 | 08:43 AM
Christi@n's Avatar
Christi@n
Default Rear diff proper level
i've recently replaced fluid on mine 1995, and added fluid till oil starts dripping out from filling hole thinking that is right procedure
though i've just read on chilton's manual that level should be about 10mm above filling hole...?
Any suggestion, you know is right?
Also seems (always on chilton's readed) that there is a drain plug on rear diff and this is the bolt in the center of the bottom rear plate placed. (I've used syphon pump to suck out old fluid)
Old Sep 18, 2015 | 08:53 AM
WVZR-1's Avatar
WVZR-1
You've done it correctly. If the car is "straight and level" you're fine. If the rear is 3ft higher than the front axle then you've likely got issues.
You don't have a FSM for your car?
Old Sep 18, 2015 | 03:53 PM
Christi@n's Avatar
Christi@n
To Rear diff proper level
