Background:
Tried to wash the kitty tracks :mad off of the windshield on the way to work yesterday. Wipers worked but no fluid. Checked reservoir - no fluid. No problem have some at home. Grandson was visiting so asked him to help. Poured fluid in tank - pours out bottom! Bad hose or tank. In the mean time, Josh asked were to put the fluid bottle and I told him just put it in the back. He did not know about the package cover. Pulled it loose form the back when 1/2 gallon of wiper fluid hit the cover. So, if you are still with me here, two questions. 1) How hard is it to R&R the wiper fluid reservoir and 2) how do you R&R and reset the package cover?
It’s not real bad. Just loosen the bolts/screws holding the inner fender. You should be able to do a look-see. If that isn’t enough access just remove the panel, same thing as changing the battery.
Sorry I don’t know what you are talking about with the “package cover”.
