Sealing header collector
Old Sep 22, 2015 | 08:30 AM
9T3VETTE's Avatar
9T3VETTE
Default Sealing header collector
For the life of me, I cannot get the slip fit header collectors to seal on this thing. It's got the annoying tick, tick, tick, tick when warm.
Any suggestions? I ordered a set of these clamps from Summit, but unfortunately they wont fit because the o2 sensor bung is in the way
http://www.summitracing.com/parts/sum-692300
Old Sep 22, 2015 | 08:52 AM
blackozvet's Avatar
blackozvet
have you tried a bead of RTV silicone ?
Old Sep 22, 2015 | 08:57 AM
WVZR-1's Avatar
WVZR-1
Never needed to do it BUT I don't know why you can't modify the clamp to use even with the O2 bung obstruction OR perhaps just a quality "band style" clamp constructed similarly to the one you linked to except a single diameter.
http://www.summitracing.com/parts/wl...FUYXHwodMdsHBg
And since it's a "slip-fit" put your hands on a 2 3/4 or 3" or whatever size pipe expander and just confirm that the header outlet is actually round and formed correctly.
Old Sep 22, 2015 | 09:13 AM
JackDidley's Avatar
JackDidley
Red RTV will seal it.
Old Sep 22, 2015 | 01:06 PM
9T3VETTE's Avatar
9T3VETTE
Thanks for the tip guys, i'll try sealing it up with RTV.
I thought about modifying the summit clamp to clear the o2 sensor bung, but my thinking would tell me the clamping force would be uneven and leak...
Old Sep 22, 2015 | 03:15 PM
WVZR-1's Avatar
WVZR-1
WHY TRY - just correct it and be done with it. Get a correct pipe expander and make sure everything is round and your "slip-fit" should get well. I don't know what diameter your collector is supposed to be but I believe the "chain" auto-parts stores keep a larger for loan that should do likely 2 3/4 or 3.
A hole-saw should work on the clamp you have and I don't see how that could compromise the clamping force of the clamp.
Old Sep 22, 2015 | 08:16 PM
blackozvet's Avatar
blackozvet
RTV does a good job of sealing, you can even use it as a header gasket, the only downside is if you take it apart you have to clean all the rtv off the surface before re-assembly.
Old Sep 25, 2015 | 10:03 PM
Rob31's Avatar
Rob31
A V-band clamp will cure it ..
To Sealing header collector
