A/C compressor moan & vibration
Old Aug 23, 2002 | 05:20 PM
vetracer's Avatar
vetracer
Default A/C compressor moan & vibration
My '86 has a nasty vibration coming from somewhere in the maze of pulleys and brackets when the A/C is on at idle. I have replaced the belt tensioner and compressor, checked all accessible bolts, and even added a "frisbee" from an '88 but still no luck. Also added GM bracket from power steering pump to block per GM service bulletin on this problem. Anyone else been down this road and figured it out?
Old Aug 23, 2002 | 07:25 PM
88JDO's Avatar
88JDO
Default Re: A/C compressor moan & vibration (vetracer)
I had a similar problem with my 94 S-10 Blazer a few months ago. Turned out that one of the alternator bolts was loose. Check your alternator, power steering, and smog pump (if you have one) bracket bolts for tightness. It's worth a look. Maybe the A/C clutch is going.
