question about egr test
Old Sep 26, 2015 | 11:58 AM
mlm0's Avatar
mlm0
Default question about egr test
1989, auto trans, stock, 50,000 miles
I have been working on a bad idle problem and seems to go away as rpm increses. I want to test the egr to see if it is leaking at idle and not fully seating.
My understanding is that at idle, I have no metered vacuum going to the egr valve, and thus should be fully seated in the closed position.
If I disconect vacuum line to egr at idle, and spray starter fluid into the vacuum line, the idle should rise if the egr is not fully seated, and do nothing if it is seated. Am I correct?
Old Sep 26, 2015 | 02:15 PM
mlm0's Avatar
mlm0
Hope someone knows. Don't want to make mistake and hurt engine
Old Sep 26, 2015 | 08:27 PM
jv9999's Avatar
jv9999
That's not really going to tell if the EGR is seated, only that the diaphragm is good. The only sure way (that I know of) is to pull it and look.
Old Sep 26, 2015 | 09:37 PM
mlm0's Avatar
mlm0
I did not think about that. Thanks
Old Sep 26, 2015 | 09:55 PM
HAD2HAV2's Avatar
HAD2HAV2
If you go to the trouble to take your EGR valve out, have a replacement. Replace all the small hoses also.
Old Sep 27, 2015 | 12:13 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Old Sep 27, 2015 | 05:51 PM
mlm0's Avatar
mlm0
will do, thanks
To question about egr test
