Aftermarket balancer?
Old Aug 23, 2002 | 09:00 PM
powerslide91's Avatar
powerslide91
Default Aftermarket balancer?
Hey all,
I have installed a TPIS single mass flywheel and a Spec II clutch (sprung hub) with the OEM pressure plate. As everyone has said, there is now some driveline noise in neutral and also between ~2200 to 3000 while under load. The noise is not really a problem for me but does mean the crank is probably seeing more vibration than it would like.
Does anyone know of a good aftermarket damper that fits in these cars that could help to damper out the crank torsion?
Thanks,
Jeff
Old Aug 24, 2002 | 03:25 AM
kawboy5792's Avatar
kawboy5792
Default Re: Aftermarket balancer? (powerslide91)
give fluidamper a call, or call doug herbert performance....you can find them if you do a search for herbert performance on google. i have no real experience with this...but both of these sources should have the info you need :yesnod:
