Anyone recognize where these go?
Old Sep 27, 2015 | 10:52 AM
ThatVguy's Avatar
ThatVguy
Default Anyone recognize where these go?
It seems as though I have two stray connectors here and my pictures I took just aren't helping me. I also have mis-placed my FSM. FML.
If anyone recognizes where these might go, it would be much appreciated! This is driver side under dash.
The 2 prong wire comes out of the Steering Column, it looks like maybe it's a ground wire. The 4 wire comes out of the main harness and It's not in proximity to anything really.
The 2 prong goes into something, I can see the marks from use on the connection points. The 4 wire might just be a dud but I've no idea really.
All steering column functions & horn work, haven't tested cruise control of course though. I thought the 4 wire might go to the fog lamp or light control but those are plugged in and function correctly too. It also doesn't have enough cable length to get up there anyway. There's nothing else around this are which leads me to believe it goes to nothing.
Thanks!
Old Sep 27, 2015 | 10:59 AM
antfarmer2's Avatar
antfarmer2
could it go to a brake or clucth safety switch? what year?
Old Sep 27, 2015 | 11:04 AM
ThatVguy's Avatar
ThatVguy
1989 sorry I forget that important part every time :/
brake switches are connected, it looks like the 2 prong is the turn signal / CC wire (figures I find it *after* I post)
http://www.fullthrottlecorvette.com/...ch_p_2325.html
I still can't figure out where it really goes though. There's nothing at the firewall, the CC brake switch and brake switch have their own separate connections which are plugged in
edit;
it looks like according to SC the 4 wire may also be Cruise control related;
http://www.superchevy.com/how-to/82001/
but where do they go! Arg!!
Old Sep 27, 2015 | 11:30 AM
WVZR-1's Avatar
WVZR-1
They should go together, the one between your ring finger and thumb is a four/edge-board and the other is it's female attaching with the white tab being the retainer.
DRK BLU, DRK GRN, GRY/WHT & PNK BLK wires maybe on an '89 (colors are a guess but similar to other years I believe)
Old Sep 27, 2015 | 12:10 PM
ThatVguy's Avatar
ThatVguy
That was exactly it thank you so much! I had originally thought of that but it seemed so counter-intuitive to think a single wire would go to 4 I gave up and searched elsewhere. I had also been trying to make it go in the opposite way (horizontal to the main plug vs going down the middle) and yet..
that clip on the 4 wire slots into the notch on the 2 prong, so it only goes in one way. DUH!
Old Sep 29, 2015 | 03:48 PM
Kevova's Avatar
Kevova
that is the connector for cruise switch on turn signal lever.
Old Sep 29, 2015 | 04:02 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Exactly right!
To Anyone recognize where these go?
